Marshian Fantasy Lights
Although I have a high regard for Marshian's light products, I recently added Marshian Fantasy & SciFi Fast Render Lights. Though they are insanely fast, I cannot get them to save with the scene file. When I return, the scene file loads with Daz's default HDRI and I then have to search through the 40 lights available if I don't remember the Environment Map I used. Does anyone know what needs to be done to get the Marshian Fantasy/SciFi lights to save with the scene file ??
  • HylasHylas Posts: 5,047
    It's a known bug in DAZ Studio that they don't bother to fix, for some reason.
    All you have to do after loading the scene is click on the default HDRI and then select "none". It should revert back to how it was when you saved.
  • RtesianRtesian Posts: 10
    edited October 2023
    Marvelous response, Hylas, and thank you for making it. Yes, clicking off the Daz default HDRI restores the Marshian Light which, of course, never occurred to me I was dealing with a bug. If Marshian can, the product could use a tweak by identifying which light map is actually loaded but they beautifully light up a scene and do so quite fast. Thanx again, Hylas
    Post edited by Rtesian on
