Crash when adding collision item...
Hi all,
I get a strange issue this morning : i add smoothing modifier to a armchair. When trying to add collision item to it (character) Daz Studio crash...
Do it means that it's not possibe to add smoothong modifier to ALL props ?
Thanks a lot
  • crosswindcrosswind Posts: 6,988
    Possible but depends on the props in some cases... Though I've never experienced a similar crash, suggest you check the topology / resolution level etc. of the prop before add smoothing modifier and collision item... better case by case.
    BTW, if you wanna add collision effect in b/t a Genesis figure and a prop, the best way is to add dForce modifier / weight node to the prop then simulate with the timeline.
  • DartanbeckDartanbeck Posts: 21,574
    I've tried some things that simply don't have enough geometry, so the smoothing modifier actually breaks the prop (G8F sitting on a cushion, for example)
    But haven't had it crash yet.
    Like crosswind says, check the mesh resolution area in the parameters pane. Too high of a level on either or both items may cause a memory overload or somesuch - crash!
