I am uable to open the Scripts drop-down menu
![MegaGothmog](https://secure.gravatar.com/avatar/0bfbeb0c59a710def70d27522122e462?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F0bfbeb0c59a710def70d27522122e462_100.png)
I'm trying to make the Daz-Blender bridge work, but I am unable to open the Scripts dropdown menu.
The other menus, like File, Edit, Create, Window, Help etc. work fine. Only the Scripts menu does not respond when I click on it.
Anyone know how to fix this?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/59/3003048b8d3baf9118bcb9e4e9900b.png)
744 x 337 - 36K
You use the latest version of DazToBlender bridge? If so, its in File - Send to.. menu item. Not sure if the latest bridge works with 4.15...
Hmm... That does seem to work. Thanks!
It doesn't solve the issue of the Scripts drop-down menu not working, but at least this works.
As for 'Scripts' menu item not working, you presse F3 to check the setting there. Create a Custom Action for a script and see it could be added to the Scripts menu or not.
