Installation with DIM (DAZ Install Manager) fails on Windows
Hi all,
I wanted to know if someone of you have issues with installing Daz Studio or any other Daz3D product via DIM (DAZ Install Manager) on Windows 10 ?
I am getting the following Errors:
`C:\Users\Dirk Schiller\AppData\Roaming\DAZ 3D\InstallManager\log.txt`:
2023-10-19 08:55:34.599 [VERBOSE] :: Translator Not Found: ./language/en_DE
2023-10-19 08:55:34.599 [VERBOSE] :: File Not Found: dzInstall.ini
2023-10-19 08:55:34.599 [INFO] :: Starting CMS...
2023-10-19 08:55:34.599 [WARNING] :: CMS Connection Failed: Cannot be started by client.
2023-10-19 09:10:09.832 [INFO] :: Json Parser (1,1): Syntax error - expected '{' or '['
2023-10-19 09:10:10.249 [WARNING] :: SSL Error: Unable To Get Local Issuer Certificate - The issuer certificate of a locally looked up certificate could not be found : Certificate is valid
2023-10-19 09:10:10.249 [WARNING] :: Network Error: 0 - : SSL handshake failed
Best
Dirk
It's the last that matters (most) - see GoDaddy certificates issue
