Prop saving error (resolved)
I got an error trying to save a prop, and I don't really understand how the error origins.
The error message was a couple of lines repeated a number of times
2023-10-22 21:20:43.107 [INFO] :: 396 unmatched vertices out of 396.
2023-10-22 21:20:43.107 [INFO] :: 402 unmatched facets out of 402.
And finally a 'failed to save'.
Background is I have a rigged V4 object (an earring) I wanted to convert to a wearable preset.
So I converted the figure to a prop, and parented it to a character, and saved it as a wearable preset. Looking in the file I could see it had saved it to the data folder with a "weird" name (I was in doubt if it could use the original data file). So I would save it as a prop with a proper name, and then I got the above mentioned error.
I know I can just export and reimport, but I am curious why it happened, and if it can be corrected (within Daz Studio).
Dunno the reason and would like to know as well. Sometimes rig with converting from TriAx to General Weight might work.
That was also my idea, but couldn't find a way of converting a prop.
So I converted the prop to a figure and back to a prop, and then it worked...
Okay, got it. Thanks !
