Notes
LoonyLoony Posts: 1,817
edited October 2023 in Product Suggestions
Could we please get finally something like this for Daz3d? There was already a notes plugin but it caused only errors and got then taken down
other people asked for it too:
So, any skilled coder can do it? I know the one plugin who was in the stores, should add notes even to single props/nodes etc. that sounds very handy!
Edit: currently I found this:
https://www.daz3d.com/forums/discussion/286646/scene-notes-freebie
but neeed to test it :<
Post edited by Loony on
  • barbultbarbult Posts: 24,883
    Look at V3D Super Save.
  • It's a bit of a hack, but you could do this...
    Create a primitive in your scene. Anything would do, bit a yellow plane would be appropriate. Make sure you set its "Visible in Render" property to false. You can change its name to "Notes" or similar.
    Select the object in your scene and open the Surfaces tab. Near the top is "Tags" click the [...] button and it opens a dialog where you can enter free text.
    Sure it's a hack, but it's available today and won't cost you anything. It doesn't seem any worse than storing the tonemapper & environment properties as a node in the scene.
  • LoonyLoony Posts: 1,817
    The note ist only visible during saving? Sounds bad :( --- About the surface, I would pretty sure forget that :( I really would like a better solution.
