How to move characters imported through Diffeomorphic
Hi everyone.
Something weird is going on with my Diffeomorphic imports. When I select the figure (imported from DAZ to blender) completely and try go move it, only the clothes and the props move, not the actual figure.
I also checked in Object properties, to see if there were any locks there: there were. I went through many sub-parts of the character one by one removing those locks. But many of them are not even selectable so I don't think all locks even got removed (?)
Including screenshots below.
If anybody else knows what I'm not doing right then that will be great help. Thanks.
(The character rig that's not moving here is not even selectable. I can click on it directly or go to the hierarchy and try to select it but nothing happens.)
Some parts of the character had lock clicked here. Unclicked them one by one tediously, but many are not even selectable and the character still won't move.
The figures are rigged for animation so locks are in place where you can't use the controls. This is correct as you have to move the armature, not the mesh. Then you need to merge the rigs that's done as default by easy import if you use it.
https://bitbucket.org/Diffeomorphic/import_daz/wiki/Import/Easy Import DAZ
