Multiple LOG files generated in latest BETA Build 4.21.1.108 - How can this be disabled?
I just noticed another new "feature" in the latest BETA Build 4.21.1.108 that generates multiple log.txt files.
I only want one log.txt file.
  • crosswindcrosswind Posts: 8,128
    You've found multiple log files in %appdata%\DAZ 3D\Studio4 Public Build\ ? with sequential suffix or something ?
  • A given folder may contain only one log.txt file - that is an operating system limit. If you have files in sub-folders, are they perhaps from plug-ins? You could use http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/plugins/plugins_load_config/start to disable all non-Daz plug-ins and see if the isue persists. Or have you had stability issues and these are from compressed crash reports (which will not be created without your asking for them)?
  • CA415CA415 Posts: 165
    I found the culprit.
    The latest update of Windows 11 apparently changed the default settings for Notepad as show in the screen-shot attached.  Just change the settings to "Open in a new window" and "Open a new window."
    This coincidentally appeared around the same time the latest DAZ Studio BETA was released.
    2023-10-29 08_13_17-DAZ Studio 4.21 Pro Public Build - !!!-Empty-2023-Medium Figure-Figure Height-2..png
    2633 x 1110 - 575K
