bones
hi i got that problem is possible redo bones ? if i delete one bone and scale it i add rigging to shape, it back to the original position
893 x 844 - 64K
No, only Undo would help if you deleted a bone.
If you mean Adjust rigging to Shape that is to help with morphs - it requires that the bones be correctly set up for the figure, and the rigging memorised; when a shape is applied the command will move, and optionally rotate, the bones so that they have the same relationship to the new shape as they do to the base shape in their memorised state. Once the comand is done, and following any further manual tweaks, the modifications are lonked to the shape (usually via ERC Freeze) and the adjustments reset, so that the figure is in its base shape and the adjustments are auto-applied as the shape is.
