Does DS use an algorithm for making some edges sharp? [Solved]
![lukon100](https://delorean.daz3d.com/forums/uploads/userpics/237/n6MJ02TFS0O4B.jpg)
I make hard surface models in Blender, transfer them to DS via .obj, and find that some of the edges are sharp, as if I had marked them to be sharp in Blender. But I did no such marking.
Is DS doing this? Or is Blender still marking some edges as sharp to spite my various attempts to prevent it from doing so?
Near as I can tell, either DS or Blender is deciding which edges to make sharp according to the rule: if the dihedral angle is 90 degrees or less, make it sharp.
But which program is doing this, DS or Blender?
Post edited by lukon100 on
Both probably do it separately - in DS it is in the Surfaces pane, look for Smoothing Angle.
Thanks for the solution, Richard. Adjusting the angle up fixed it.
In DS 4.11, the property in the Surfaces tab presents as a boolean on/off button for "Smoothing", and directly under it is the "Angle" property wherein ya type the degree threshhold.
