Zbrush Crash
Update to Daz Studio 4.22.0.1. Goz opens Zbrush but crashes just seconds afterward. I tried this.....
"With DS and ZBrush closed, go to C:\Users\Public\Pixologic\ . Remove any OBJ files in the GoZBrush folder, and the GoZObject*.txt files. In the GoZProject folder, remove the contents of any folders except for any log files (I have a Photoshop install log in my GoZProject \default folder, not sure if that's needed or not). Try restarting ZBrush, go to Preferences>GoZ and make sure there's an entry for DAZ Studio and that the path is right. Try using GoZ from DS to ZBrush again"
I have tried my 2023 and 2022 versions of Zbrush but it keeps crashing. Also, in Zbrush and checking the Goz file paths (preferences>GoZ), Daz is not listed as it has been in the past. Before the update, it was working successfully with Zbrush 2022.
  • I forgot to add. GoZ for DAZ Studio keeps showing up in " Ready to Download". If I download, it installs and shows in "Installed" for a few seconds. It then reappears in "Ready to Download".
  • crosswindcrosswind Posts: 7,952
    edited November 2023
    If so, you did not fully close DS before installing GoZ plugin, and you must've checked 'Delete Package Once Installed' in DIM - Ready to Intalll tab (at the bottom).
    You must fully close DS before installing any plugin and/or plugin update. Pls try again.
    Post edited by crosswind on
    I double-checked both ZB 2022 and 2023, there was no problem if GoZ plugin was correctly installed.
  • It was the "Delete Package". I have never noticed that before and must have inadvertently turned it on. Thank you.
