4.22 crashes when rendering
Anyone else having Daz crash when rendering since updating to 4.22? Or any ways to fix said problem?
Anything I render since updating to 4.22 just crashes Daz. Hoping I'm not the only one.
«13
  • crosswindcrosswind Posts: 7,880
    Post you DS log if you pls..
  • You are not alone, I get this window after running a render or pre-render.
    533 x 510 - 33K
    zip
    zip
    DAZStudio_error_report_231102-115738.zip
    183K
  • Having this same bug. Crashing when rendering, when using the Iray viewport, etc.
    zip
    zip
    DAZStudio_error_report_231102-063336.zip
    203K
  • Out of Touch Hairs? Many have been updated to fix an issue with their custom shader, so check DIM/DazCentral/Connect for updates, but if you have one that is an issue remove any map from its Transmitted Colour proeprty (in the Editor tab of the Surfaces pane).
    DS log is needed rather than couldlog. DS - Help - Troubleshooting - View Log File... From the log we may know what objects did you use in the scene..
    So, btw, I saw a few cases of crash these days... did you guys also happen to use OOT's hair in your scenes ?
  • Here is one of my log files when it crashes during rendering.
    txt
    txt
    log.txt
    2M
  • You don't appear to have any Out Of Touch hairs, but you do have their Daily Casuals 0 it may be worth checking that none of those have a map applied to Transmitted Colour in the Surfaces pane. However, it does look as if memory is also an issue.
    You have GeForce GTX 1660 and ran out of VRAM. Usually one will get black render window with Nvidia 20 - 40 series cards when running out of VARM. But with 9 - 10 series, one usually ends up with Ds crash.
    Pls try to use Scene Optimizer to optimize the VRAM consumption of your scene, and install GPU-Z to monitor VRAM usage.
    856 x 912 - 108K
    edited November 2023
    And 16GB's of RAM is also not enough
    Post edited by PerttiA on
    Not enough indeed
  • Having the same issue.  Crashes just when i am about to render.
    Test with a bare G8 or G9 first.
  • neomanneoman Posts: 75
    I'm having the same problem.  This is ridiculous.  Some of my scene will render, while others crash now.  I'm running a GeForce RTX 3070, so don't tell me it's out of VRAM, the scenes work perfectly yesterday with Daz Studio 4.21.
    691 x 664 - 171K
    Test with a bare G8 or G9 first. And the same question: is there an OOT hair in your scene?
    May I ask what the bare figure test shows me?  Some of my scenes render fine, while others crash... With the scenes that crash I checked the hair, no OOT hair...
    Post edited by neoman on
    A successfull render with a pure bare Base Figure can more or less prove that you don't have engine / driver issue but probably asset issue that results in render failure or crash...
    If there's no OOT hair in the problematic scene, I think you may test it by a 'process of elimination'. For instance, remove all hairs first then test, then remove all garments, till you find the culprit.
    Incredible, so I have to go through my scenes prop by prop to find why it won't render.  How exactly is this an upgrade when yesterday I could open and run any scene I've created???
  • barbultbarbult Posts: 24,750
    Have you looked at the log file to see why the render failed?
  • geoff6geoff6 Posts: 250
    I have a similar problem when rendering. An asset which rendered quickly and well with 4.21 yesterday, won't render today. Daz doesn't crash, I just get a blank image. Can somebody explain, as mcgarhart_3bfd88cc5f said; not so much an upgrade as a downgrade.
    Thanks in advance,
    D
  • PitmaticPitmatic Posts: 917
    Hi
    I am getting crashes on some scenes that worked perfectly just before the update for example I have
    https://www.daz3d.com/lyra-hd-for-genesis-8-female
    Wearing
    https://www.daz3d.com/leony-wet-and-dry-ponytail-hair-for-genesis-3-and-8-females
    sitting in the water tank from
    https://www.daz3d.com/mad-science-laboratory
    and it crashes now where as 4.21 had no problem with it and hour earlier.
    the log file shows a load of deallocation errors and i tried deleting items for the scene and found it was the Leony hair another thread mentioned the trans map and i deleted that in surfaces and the scene now renders. I did not update the nvidia driver so why did 4.22 crash on this?
    Also i noticed errors with Lyra's ears in the log is this something to worry about?
    Edit I have tried more hairs and it seem to be other OOT that crash very confused
    2023-11-04 11:32:19.006 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Reached internal texture limit on material instance 'DS_Lyra__Face_18d9_8214', retrying JIT-compilation.
    2023-11-04 11:32:19.010 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Lyra__Face_18d9_8214' uses MDL JIT compilation.
    2023-11-04 11:32:19.011 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Reached internal texture limit on material instance 'DS_Lyra__Ears_18dc_8301', retrying JIT-compilation.
    2023-11-04 11:32:19.015 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Lyra__Ears_18dc_8301' uses MDL JIT compilation.
    2023-11-04 11:32:19.015 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Reached internal texture limit on material instance 'DS_Lyra__EyeSocket_18de_8377', retrying JIT-compilation.
    2023-11-04 11:32:19.019 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Lyra__EyeSocket_18de_8377' uses MDL JIT compilation.
    2023-11-04 11:32:19.021 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Leony Ponytail Genesis 8 Female__Side2_1913_8571' uses MDL JIT compilation.
    2023-11-04 11:32:19.131 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 644 textures, 56 lambdas (56 unique)
    2023-11-04 11:32:19.132 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Computing 1 flux compensation factor took 0.001 s
    2023-11-04 11:32:19.132 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (3 light sources with 2106 triangles, 3 instances) took 0.001 s
    2023-11-04 11:32:19.133 Iray (Scene Update) : Updating environment
    2023-11-04 11:32:19.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2023-11-04 11:32:19.133 Iray (Scene Update) : Updating code
    2023-11-04 11:32:19.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
    2023-11-04 11:32:19.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
    2023-11-04 11:32:19.133 Iray (Scene Update) : Updating textures
    2023-11-04 11:32:19.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating volumes
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating lens data
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating lights
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating instance topology
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating flags
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2023-11-04 11:32:19.141 Iray (Scene Update) : Updating backplate
    2023-11-04 11:32:19.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2023-11-04 11:32:19.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
    2023-11-04 11:32:19.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
    2023-11-04 11:32:19.141 Iray (Scene Update) : Updating decals
    2023-11-04 11:32:19.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2023-11-04 11:32:19.185 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using no convergence estimate.
    2023-11-04 11:32:19.185 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2023-11-04 11:32:19.229 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2023-11-04 11:32:19.229 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2023-11-04 11:32:19.255 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2023-11-04 11:32:19.426 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2023-11-04 11:32:19.426 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060)
    2023-11-04 11:32:19.426 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2023-11-04 11:32:19.426 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3060): Processing scene...
    2023-11-04 11:32:19.426 Iray (Scene Access) : Retrieving geometry
    2023-11-04 11:32:19.426 Iray (Scene Access) : Retrieving device geometry
    2023-11-04 11:32:19.679 Iray (Scene Access) : Retrieving volumes
    2023-11-04 11:32:19.679 Iray (Scene Access) : Retrieving textures
    2023-11-04 11:32:24.669 Iray (Scene Access) : Retrieving device textures
    2023-11-04 11:32:25.192 Iray (Scene Access) : Retrieving flags
    2023-11-04 11:32:25.192 Iray (Scene Access) : Retrieving device flags
    2023-11-04 11:32:25.193 Iray (Scene Access) : Retrieving lights
    2023-11-04 11:32:25.193 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Importing lights for motion time 0
    2023-11-04 11:32:25.193 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Initializing light hierarchy.
    2023-11-04 11:32:25.205 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Light hierarchy initialization took 0.013 s
    2023-11-04 11:32:25.206 Iray (Scene Access) : Retrieving device lights
    2023-11-04 11:32:25.206 Iray (Scene Access) : Retrieving section objects
    2023-11-04 11:32:25.206 Iray (Scene Access) : Retrieving device section objects
    2023-11-04 11:32:25.206 Iray (Scene Access) : Retrieving materials
    2023-11-04 11:32:25.208 Iray (Scene Access) : Compiling custom code
    2023-11-04 11:32:25.345 Iray (Scene Access) : Retrieving environment
    2023-11-04 11:32:25.346 Iray (Scene Access) : Retrieving device environment
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving backplate
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving device backplate
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving decals
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving device decals
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving motion transform data
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving device motion transform data
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving lens data
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving device lens data
    2023-11-04 11:32:25.581 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : JIT-linking wavefront kernel in 0.224 s
    2023-11-04 11:32:25.586 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): Scene processed in 6.160s
    2023-11-04 11:32:25.593 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): Allocated 305.335 MiB for frame buffer
    2023-11-04 11:32:25.593 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): Allocated 1.969 GiB of work space (2048k active samples in 0.000s)
    2023-11-04 11:32:25.593 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): Optimizing for cooperative usage (performance could be sacrificed)
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Kernel [8] (ShadowEvalSr      ) failed after 0.014s
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while launching CUDA renderer in <internal>:908)
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Failed to launch renderer
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Device failed while rendering
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.3   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3060) is no longer available for rendering.
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.3   IRAY   rend warn : All available GPUs failed.
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.3   IRAY   rend warn : No devices activated. Enabling CPU fallback.
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while initializing memory buffer)
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: All workers failed: aborting render
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
    2023-11-04 11:32:25.692 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
    2023-11-04 11:32:25.692 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
    2023-11-04 11:32:25.693 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 20 cores for rendering
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend progr: CPU: Processing scene...
    2023-11-04 11:32:25.693 Iray (Scene Access) : Retrieving geometry
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Using Embree 3.13.2
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Initializing Embree
    2023-11-04 11:32:26.374 Iray (Scene Access) : Retrieving volumes
    2023-11-04 11:32:26.375 Iray (Scene Access) : Retrieving textures
    2023-11-04 11:32:26.375 Iray (Scene Access) : Retrieving flags
    2023-11-04 11:32:26.375 Iray (Scene Access) : Retrieving section objects
    2023-11-04 11:32:26.375 Iray (Scene Access) : Retrieving lights
    2023-11-04 11:32:26.376 Iray (Scene Access) : Retrieving materials
    2023-11-04 11:32:26.376 Iray (Scene Access) : Compiling custom code
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving environment
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving backplate
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving decals
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving motion transform data
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving lens data
    2023-11-04 11:32:26.548 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CPU: Scene processed in 0.855s
    and thats the end of the log when it crashes
    Post edited by Pitmatic on
  • frank0314frank0314 Posts: 14,258
    Are you using the updated NVIDI driver? This version of DS requires it.
  • Pitmatic said:
    Hi
    Wearing
    Which is by Out of Touch and presumably is calling the custom shader with a map in the Transmitted Colour channel - select the hair, open the Surfaces pane, select the hair there, and type transm in the filter box - click the little icon/nano-thumbnail next to the colour picker for the transmitted Colour and select None.
    Are there hairsd in the scenes that crash? Which? You can try seelcting them and treat them as in my reply above, there is a good chance that will fix the issue. You could also, if you use an external isntalaltion method, try (re)installing a recent hair by Out Of Touch to make sure that the latest (fixed, hopefully) version of the shared file is on the system.
    Right to be clear :)
    This morning that scene and many many others as i use a lot of OOT hair rendered just fine but upgrading to 4.22 caused this issue to occur hence my confusuion.
    Leoony hair and classic bob hair crashed post update and were updated in january when the patch came out i am reinstalling the leony hair now but it might take a while on my tragic rural internet will update when its done
    Reinstalled the leony hair and it still crashes and shows no pending updates deleting the trans map works but this was patched ages ago
    470 x 244 - 42K
  • FedermannFedermann Posts: 111
    DS 4.22 silently (no crash dialog) closed itself a few minutes after a succesfull render (which I did not save), in those minutes I did not work with DS or anything else on my computer.
    Feel a bit stupid now about always agreeing to the latest update. I realize I am relatively lucky not to experience a crash during the render process as so many of you reported. 4.21 was quite stable for me with (render) crashes being rare.
    Post edited by Federmann on
  • I've been rendering for years on 16gb of ram and it's been fine until the Daz update.
    Not every render crashes. A base genesis 3, 8, 8.1 & 9 model all render fine.
    Certain scenes render fine that have many models and a lot of props.
    Other just crash. I tried rendering a scene I rendered the day prior to the update with no luck.
    If I'm not mistaken RAM is used while setting up your scene. The larger amount of RAM you have the bigger of a scene you can make without lags. Your GPU and/or processor are utilized for rendering depending on your render settings.
    RAM is also needed to prepare the data for the renderer, since the working data is not what Iray wants (it doesn't need modifiers, it does need high-resoloution meshes)
  • Same issue today.  Would seem that DAZ needs to address fixing the issue. I managed a  software development shop or many years and this should not be the end users problem to fix. If its a Vendor issue then coordinate a fix with them.
    Best Regards..
    Best Regards..
    It seems that not all prodcuts were updated, though many were. Instalaltion order therefore matters, installing an unfixed product after the fixed will obviously rstore the problem. It also matters that there not be an older version of the file, not fixed, found before the fixed version.
