HP Ragna for Genesis 8 Female missing bones(?)
in The Commons
Using Daz3D v4.22, this is a fresh install of the character Ragna from a newly launched DazStudio. I have tried working with the Actor and then Shaping on the basic G8F model. No matter how I tried this, I ended up with the problems shown in the image. All joints do the same. I have uninstalled and reinstalled the Ragna model to no effect.
I have loaded other models, including the basic G8F model, which worked perfectly.
Has anyone seen this and know a workaround?
Looks to me like there are bones there, just not in the right places. Same happened here while I was adding morphs to a new TriAx figure I was creating from A3:
In this case A3's arms were well above the default bone line & needed to be adjusted to the shape & an ERC freeze applied.
Can I suggest you zero the pose, then select menu option 'Edit| Figure| Rigging| Adjust Rigging to Shape' and then re-apply a pose. If that makes it work, there is a problem with the character preset, and I suggest you first re-install, and if that doesn't cure it, open a ticket to report a problem.
Regards,
Richard.
Yikes! Looks like a case for customer service.
You're image will probably be removed soon as it doesn't follow the nudity rules here.
Damn! I did not think of the nudity, just the mangled joints. I will correct and repost it.
The (deleted) pic was after a reinstall of Daz and an uninstall and reinstall of Ragna. After starting Daz, I only opened the Ragna model and immediately bent the arm.
I'm in bed now on my laptop (05:08), when I get up, I'll get on my desktop and rerender the pic with a bra.
This https://www.daz3d.com/hp-ragna-for-genesis-8-female ? It seems to pose OK in the images, and it's been available for about five years without previous issue reports that I can recall. It's possible that someother content is causing a conflict - check the log file for errors after loading the character.
I've seen certain poses cause such effects:
https://www.daz3d.com/forums/discussion/comment/2775271/#Comment_2775271
I thought some poses were at fault, too. That's why I updated Daz to v2.44, uninstalled/reinstalled Ragna, did a DazStudio clean start, loaded Ragna, and clicked on her forearm, bending the arm at the elbow. Sigh.
Other G8F models work fine, just Ragna bites.
I do not think what led to your problem, Richard & Tracy, is the same as I have since the Ragna is a fresh install in a blank scene, but I'll check it out. Thanx.
Sorry, it took me so long to fix (clothe) Ragna.
I am still looking into this problem. I was able to use the Ragna model a few months ago. In the last couple of days, I dug the DUF file that the character I was using to find these mangled joints or what have you.
I have more pressing concerns as I am working on my AVN at present. The character that uses the Ragna model is Random, who will be making her appearance a few chapters later.
