Looking for Antique Bedwarmer
Escribano
Does anyone know of any sets that include an old-fashioned bedwarmer prop? I might have a go at kitbashing one for a scene I'm working on, but thought I would check to see if there were any existing props first.
1190 x 1587 - 274K
I thought it might be so as well, but can't find it in my collection either. I'm certain I've seen one somewhere, but can't figure out where.
What about cobbling something together with these? https://www.daz3d.com/mk-circular-fan It's not going to be accurate, but if you make the fan parts thicker and use some kind of appropriate shaders, can you make it work?
Thanks! I might be able to do something with that for the handle. I just need to find some sort of cooking pot or pan with an engraved lid that I could flatten down for the part that holds the coals.
I remembered someone looking one for one years ago
so I tried bedwarmer site:daz3d.com in Google search
and the only other result was a kitty belonging to another forum user who was the spitting image of my late cat Lynx
he was a good bedwarmer too
no help but the post I recalled was so long ago it must have been on the old forum
there are non DAZ ones around https://www.turbosquid.com/3d-models/bed-warmer-3d-1837761
all the same by same person varying prices different sites, bit weird looking though
honestly a lidded frypan, 2 pans or pot with the handle extended would pass
I found a chestnut pan from 2008 while I was going through my old files. It was in my DAZ Christmas downloads from that year. The file is RH Chestnut pan.zip . If you've got it kicking around, it would make an absolutely dandy bed warmer. The lid opens and closes and the chestnuts are separate. It could be retextured with a more ornate design if desired, and there are enough freebie coals around if needed.
Does it still open? Mine didn't (I still have the original models so it could be rebuilt fairly easily).
I opened it in an old version of DAZ (2.3). It's a beauty!
Thank you. If it looks as if Escribano can use it I will redo the rigging and put a zip up.
