POSES FOR G9 ON CUSTOM RIGGING
Kainjy
Hi
I have a custom model that I rigged in DAZ.
Is there a way to make it compatible with G9 Poses ?
For example a cloth can be posed (by a pose file) without a G9 figured fitted to: DAZ read joints name and applies the joint rotation even if there is a different rigging (example: pants don't have upper body joints).
So what should I do to make my custom rigging compatible with G9 figure ? I have already renamed my joints and checked every axis orientation like a G9 figure.
PS I don't want to use Transfer To
Thanks
Post edited by Kainjy on
Fitted items require the same joint centres, you may be better making a Genesis 9 clone for your figure and letting AutoFit handle conversion - but note that you would not bae able to share that, if you plan to distribute the figure.
@Richard Haseltine
I don't want a fitted item.. I want to create a standalone figure.
It's a robot with only leg, torso and arms joint: no fingers, no mouth, no expression. It's a mechanical figure so I only have rigid parts. I don't need all G9 joints but only some ones to be able to apply G9 poses. This figure has also different body proportion, so I should heavly morph a G9 to use Tarnsfer to.
I also tried to use a Fit to.. because it's an unknown figure DAZ destroys old rigging to project all G9 joints and create new weight maps
If the proportionsa e different then the poses won't really work anyway - but you could look at the free scripts for cionverting between generations to give you an idea of how to do it (but don't copy the code, unless it says you can).
Yes I know.. poses won't be precise but it's better to have a partial compatibility than none.
Where can I find these scripts ?
Thanks
Here are a bunch of the free scripts in this thread https://www.daz3d.com/forums/discussion/293/list-of-free-daz-studio-script-and-plugins
