Reverting back to 4.15?
deleted userdeleted user Posts: 1,204
edited November 2023 in The Commons
I am NOT liking this new version of daz... AT ALL!!! So many changes are not a single one of them I like..
They changed a lot! a lot a lot and none of it is for the better. I cant handle this version... How do I go back to 4.15?
I mean I used to be able tozero my figure but lock the morphs I want to keep... Now?... Not an option.
I cant edit the parameters settings on many things. I do not like the "New Scene" Pop up... Icing on the cake, this is by far the Chunkyest, Laggiest version of Daz3d I have ever had the displeasure of using.
If it aint broke dont fix it... How about you fix the Dforce Explosion issue instead of changing everything all weird, for no reason...
Post edited by deleted user on
  • crosswindcrosswind Posts: 7,520
    If you have a backup of 4.15 installation package, or if you can get one from Daz Customer Support by sending a support request...
  • Where is the Parameter settings gone for Render settings?.... I need that!!! THATS CRITICAL for my render settings...
    Oh.. if so, you may bring it back as below, press F3 ~, Expand... drag Parameter Settings... from Styled Properties group to the right Menu - Property Options (Element).
    931 x 779 - 82K
    Post edited by crosswind on
  • and why is it ignoring my locks when I Crtl-Shift-F? It didnt do that before.
    Ah...? What....?
  • Say I make a character, but I dont like about 20 morphs applied. Typically what I will do, is Lock the Morphs I want to keep, and then Zero the figure. Which removes all the morphs accpet for those which were locked.
    But... All the sudden, even Locked Morphs go to Zero.
    No such an issue on my side, Ctrl + Shift + F does not restore Locked properties...
  • deleted userdeleted user Posts: 1,204
    Are you using Genesis 8 or 9 for that test?
    I use Genesis 8 as my primary
    Previously G9... also tested G8 just now, found no problem either.
  • Are you hitting Restore, or Zero? Which by the way this new pop up option is also very annoying.
    I pressed Ctrl+Shift+F for Restore, so no pop-up. Zero shows the dialogue...because of G9's default values...there's no way to block it.
    Although Genesis 9 made the issue very obvious there had been issues with inappropriate zeroing before that.
