Can't bend move multiple joints in DAZ 4.22
![douglasbushong](https://secure.gravatar.com/avatar/1e712ae04c402f20895da5f23d431446?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F1e712ae04c402f20895da5f23d431446_100.png)
The title pretty much says it all.
I've been using DAZ for over 10 years now, and I've never run into this problem before. In previous versions, I was able to select multiple joints and bend them at the same time. For example, I could grab the three joints of a find, adjust the "bend" parameter, and allow the fingers to "curl" as I made the adjustment.
I recently installed DAZ 4.22 on a new computer, and when I attempt to adjust multiple finger joints at once, it only adjusts one of the joints. I have to bend each joint, one at a time.
Is there a default general setting in the more recent versions of DAZ that prevents us from bending multiple joints at once?
Have you checked Consolidate Properties option in that hamburger menu?
Thanks for the follow-up. Yes, I"ve checked the Consolidate Properties option. See the attached image. it's still nto allowing me to bend multiple joints.
Hss.. correct ~ I tried with no problem. Pls check the clip: - https://mega.nz/file/zThwDToR#tJFFQm9C-ydZlerD7heBAiqVN4xxYJhKXZVv1dSxx30
Here is a short video of what I am seeing when I attempt to select multiple joints. One interesting thing is that it appears to be only bending the first joint I select. Noticed that it initially only bends Left Index 1, and the second time it only bends Left Mid 3.
https://www.youtube.com/watch?v=k2_8Y5bnfVM
Genesis 1 ? Let me try...
Seems Genesis 1 does not support Consolidate... you have to multi-select the items in the list of Parameters pane.
I've tried it with Genesis 1, Genesis 9, and Victoria 4. The same problem persists.
Again, I had DAZ on another machine, and I did not experience this problem with Genesis 1, 9, or Victoria 4. It seems like there may be a generalized setting causing the issue after a fresh in stall of the latest version.
Maybe a glitch ~~ sometimes it works, sometimes it doesn't ~~ https://mega.nz/file/jXIE0bRQ#kNhfFHyo1Qu8AuTreJqFc0fZ7qZM5lwhlgpxNJ4JDpE
