Laguna Mermaid Set issues
I am having an issue with the Laguna Mermaid set.
https://www.daz3d.com/laguna-mermaid-set-for-genesis-3-female-s
When I apply it to a Genesis 3 Female figure a strange white band is visible at the waist just above the tail.
How do I get rid of this white area so that it transitions from skin to scales?
641 x 801 - 295K
  • GordigGordig Posts: 10,124
    That's the torso surface on the tail. Simply copy the torso surface from the figure to that.
  • NorthOf45NorthOf45 Posts: 5,523
    It's a part of the Tail, a blend zone to mix with the character's skin. There is a hint in the materials presets folder that says select the Tail, and apply the character's skin. Use the same material preset as the Genesis 3 Female (Jade or Indigo, if you got the fantasy pack, or whatever) . Not to be confused with the Tail Geoshell.
  • vonHobovonHobo Posts: 1,692
    That worked! Thank you so much!
    Thank you!
    If you're interested, this thread describes how to adapt the Laguna tail to G8.
