Script for Environment Set Splitter (Code 66) does not load
![antonsinabell](https://secure.gravatar.com/avatar/b0977632d7683324bc11ca347cf88a98?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fb0977632d7683324bc11ca347cf88a98_100.png)
Hi,
just bought and installed the "Environment Set Splitter" (by Code 66) and on doubleclick the scripts refuse to load - so nothing happens. Version = DS 4.22 Pro.
But Log entries as follows:
2023-11-14 20:43:58.913 [INFO] :: Loading script: E:/Daz_Content/data/cloud/1_87033/scripts/code 66/environment set splitter/es splitter.dse
2023-11-14 20:43:58.937 [INFO] :: Script executed successfully: E:/Daz_Content/data/cloud/1_87033/scripts/code 66/environment set splitter/es splitter.dse
2023-11-14 20:44:02.912 [INFO] :: Loading script: E:/Daz_Content/data/cloud/1_87033/scripts/code 66/environment set splitter/resources/splitengine.dse
2023-11-14 20:44:02.919 [INFO] :: Script executed successfully: E:/Daz_Content/data/cloud/1_87033/scripts/code 66/environment set splitter/resources/splitengine.dse
Am i missing something? Thing not Proper installed?
Any help appreciated - Thanx.
The path E:/Daz_Content/data/cloud/1_87033/scripts/code 66/environment set splitter/es splitter.dse indicates that you installed through Daz Studio itself (Daz Connect) - unfortunately a lot of add-on scripts fail to handle these paths, so you need to unisntall it (right-click on the product) and install through Install Manager.
Thanx - it worked, and solved some other Problems :-)
