@MartinJFrost "Tracks and Footprint decals"
Hi, when I use the footprints, I try to lay them out but they do not show up on the work screen, so when I render they are misplaced.
I try to line them up but would be a lot easier if I was able to see them in the preview screen.  Is there a way to do that?
  • Which Drawstyle are you using? Decals are an Iray feature.
  • Iray
  • ShimrianShimrian Posts: 534
    edited November 2023
    Did you make sure to move the prop to the plane or floor? The ground plane needs to be the parent object in the scene for the footprints to show up in iray preview or render.
    paw prints
    Added a picture of the Iray ground Surface Decal Node under the floor node (so floor is parent). You also need to make sure the bounding box is around midway through the floor for the prints to show up.
    3041 x 1468 - 7M
    Post edited by Shimrian on
  • will they show up in the view port (preview screen)
  • it is showing up in the render but not the preview
  • this one is before render
    2560 x 1080 - 3M
  • this was after render
    1114 x 610 - 1M
  • the footprints do not show up before the render
  • GordigGordig Posts: 10,123
    You're in texture shaded viewport mode. You need to switch to Iray Preview to see them in the viewport.
  • how do you do that
  • MelanieLMelanieL Posts: 7,437
    Click here:
    This should drop down a list including "Iray Preview" (as I recall)
    1117 x 543 - 148K
    Post edited by MelanieL on
  • tsroemitsroemi Posts: 2,818
    My, she sure has sticky feetsies ... laugh
