Need some advice on uninstalling
![jhogenboom_da69c035a9](https://secure.gravatar.com/avatar/2e6ed1ffc4df211521c76b25c56ffff2?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F2e6ed1ffc4df211521c76b25c56ffff2_100.png)
I'm running into space constraints on my hard drive, so I decided to uninstall practically everything and install as needed. I went to DIM and uninstalled. It now says I have something like 90 things installed. But when I go to DAZ, everything still seems to be there. The only difference is that it doesn't show up on Smart Content. How do I clear this stuff out of the content libraries?
Thanks for your help.
So the fils aer still there in the Content Library pane? One possibility is that you reinstalled after soemthing had wiped the manifests (the list of what was installed where) so DIM noted everything as being there before it did its isntallation, and therefore left the files behind on uninstalling so as not to break any products that shrared them. If so it should be safe to delete them, as long as you don't have other files you want to keep mixed up in the same folders.
Thanks! I'll clear the folders out.
