Installed content not loading?
![Sincronum](https://secure.gravatar.com/avatar/6b105bd44f32bb80ca5e14bc92ce671d?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F6b105bd44f32bb80ca5e14bc92ce671d_100.png)
for some reason recently alot of my installed content that worked previously suddenly stopped working and is now saying the files dont exist. would anyone be able to help?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/0c/934cda77c3770acdd900bbfe471e08.png)
1920 x 1080 - 834K
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/59/b027a75434450778833ddcf9d984e9.png)
1920 x 1080 - 676K
A couple of things to check there:
1) It looks like you have a library that OneDrive has access to - check that it hasn't "helpfully" moved those files to the cloud.
2) You appear to have libraries inside libraries which Daz Studio does not support and so oddness may ensue due to that.
The Two folders in Animals are asking for trouble - you have ensted cotnent directories, which will confues DS when it os working out what relative path to use for pointing to files within those folders.
I see that you are working online - it is possible that you had, and have somehow lost, Connect (through Daz Studio itself) installations as well as the ones made with Install Manager or Daz Central. Find the product container for the problem set, right-click on it, and if it says Uninstall do so (if it says install leave it be if you want to use DIM, if it says neither you probably are not clicking on the container).
