Gnoll figure?
Does anyone have a link to a good (DAZ compatible) Gnoll figure? I'm well aware of Gnollicious for Genesis 8 Male, but I don't feel it's monstrous enough, close enough to what I deem to be 'proper' Gnolls, creatures like these;
Of course, suggestions to get Gnollicious closer to that also welcome :-)
  • GordigGordig Posts: 10,191
    Lycan looks a bit closer to what you're looking for. You might not want to dial it in all the way, because it's a very overpowering morph.
  • Oh, yeah, that might work! Experimentation time! Thanks for the tip :-)
  • Once you have Lycan applied to get the muzzle length try adding the Face Center Depth to it (Actor/Head/Face/Real World) this is from the Genesis 8 Male Head Morphs Pack. If you need it longer just click on the "Cog" on the upper right of the morph select "Parameter Settings" and the uncheck the  "Use Limits" box on the middle right side.
  • Mixing in the Lycan and with Elliandra's tip, I got quite close to what I want. Hair is most of the Lycan hair, plus Denki hair;
    WOW! I like that Lycan!! smiley
