Ghost Lights For 4.22 No "Create Advanced Iray Node Properties" Dialog Box
Wondering why I do not have the dialog box appear when I double click it inside Default Resources?
  • crosswindcrosswind Posts: 7,891
    Completely uninstall Default Resources product if you ever installed it with Daz Connect. Then installed the latest Default Resources package with DIM.
  • Unless you did install with Connect by choice, of course. Make sure you did install the update, and if you don't use connect to install make sure you don't have an older version in another content directory.
  • neomanneoman Posts: 75
    I downloaded 4.22 with DIM.  I went into DIM and uninstalled "Default Resources" and then re-installed but nothing changed... How do I make sure it is the up to date version???
  • If DIM was online it was up to date. Have you made sure you don't have a Connect install (find the product in Content Library>Products>D, right-click on the container (the folder icon/name), and select Uninstall (which won't affect the DIM files).
