Error during rendering message
![Schaaka](https://delorean.daz3d.com/forums/uploads/userpics/178/nIN2RGBTDBL8V.png)
I was looking online trying to find a solution but couldnt really find anything.
Everything I was reading was mentioning for them to check their poly counts and render settings as they may be overloading something.
Unfortunately I don't think thats the case here with me, I have a scene I have been using assets from Teen Bedroom https://www.daz3d.com/teen-bedroom
I have hidden props and assets and narrowed down that a desk in Teen Bedroom is causing this render error message.
If I hide the desk, I can render a full scene with no problems.
If I delete everything and set render settings to defaults but only have the desk it will cause that error.
I have uninstalled and reinstalled the Teen Bedroom asset, still same error.
I have loaded the desk by it self in a fresh scene on a fresh reload and still same error.
Normally this wouldnt be a problem but I have been using this desk in one of my scenes and changing it out would not be too practical.
If anyone has any advice on the issue that would be very helpful, thanks!
Heres the Daz note log:
2023-11-20 18:39:03.080 [WARNING] :: QColor::setRgb: RGB parameters out of range
2023-11-20 18:39:03.140 [INFO] :: Rendering image
2023-11-20 18:39:03.186 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Paper_box_roughness.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
2023-11-20 18:39:03.197 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Paper_box_base_color.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
2023-11-20 18:39:03.203 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Paper_box_normal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
2023-11-20 18:39:03.205 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Ball_roughness.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
2023-11-20 18:39:03.207 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Ball_color.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
2023-11-20 18:39:03.208 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Ball_normal.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
2023-11-20 18:39:03.225 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Board_roughness.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
2023-11-20 18:39:03.226 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Board_base_color.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
2023-11-20 18:39:03.227 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Board_normal.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
2023-11-20 18:39:03.260 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Table_roughness.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
2023-11-20 18:39:03.261 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Table_base_color.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
2023-11-20 18:39:03.263 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "X:\My DAZ 3D Library\Runtime\Textures\Feng\Teen Bedroom\Table_normal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
2023-11-20 18:39:03.284 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [WARNING] - API:DATABASE :: 1.0 API db warn : Transaction is released without being committed or aborted. Automatically aborting.
2023-11-20 18:39:04.392 [INFO] :: Total Rendering Time: 1.31 seconds
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/07/da8c656db5a750f411cf12d37166a4.jpg)
http://docs.daz3d.com/doku.php/public/read_me/index/80434/start
The issue was fixed at last year-end, just update your product...
That fixed it, thanks! A small downside to saving everything locally, I went and re-downloaded it from the store and all was good.
