Easy Tip For Unaligned Earring When Rendering
stevejinta
in The Commons
Yes, it is on the right direction from the viewport and IRAY view but why wrong rotation unpurposely when render.
Please, select figure, under head there are left and right ears, select the ear which causing happy issue, try turning front-Back on parameter to exceed the limit (Minus 1-2 is fine for me)
On the viewport the earring should bounce to the unaligned position when seeing from rendering window. Now, adjust the earring with desire position, hit render to see if it's fit.
This is how I fix mine, do not ask anything more, this is the farthest I went.
I am not sure what you mean.
