Rig Bones rendering
bwise1701bwise1701 Posts: 252
Hey Folks,
having a bit of an issue with a Harness model is DS Studio Pro 4. It's made for a V3 but I've fit it to a V4 model. Which it does fit to, but for some reason I see rig bones appearing when it's loaded and they don't invis when I turn bones visibility on / off. In fact,bone visibility is off by defualt and additional bones appear when I toggle it.
Worst of all these bones render. Very confused. If I translate the character away fromt he origin the bones stay there.
Any ideas how to get rid of them?
Thanks a lot
  • Richard HaseltineRichard Haseltine Posts: 101,901
    Are you sure they are rig markers and not body handles? If they are handles you should be able to select them and hide them, or if you want to use them set them to be not Visible in render.
  • bwise1701bwise1701 Posts: 252
    I don't know what they are.
    There are no objects in the hierarchy to invis other than the geometry. And as I said the bones invis didn't work.
    The only thing I can set to not render is the actual harness geometry...
    You're using this on V4, not on Genesis with the V4 shape? AutoFit would kill the handles, if that's what they are, as bones (though you should still be able to select the surface they use and set its opacity to 0)..
