Daz studio 4.22 is unable to render ground fog
emanuela1
Daz studio 4.22 is unable to render ground fog. I saved a file with the ground fog with daz studio 4.21, with which I made a good render. When I reopened the file after installing version 4.22, the rendered result was a completely black image. By removing the fog it is possible to render, which however is much longer than in the same conditions with version 4.21, more than double.
Is there a way to fix the problem? How to make ground fog work also in version 4.22? How to speed up the render and make it return to at least the duration of the previous version? Is it a graphics card driver problem? (I have an Nvidia 536.23 driver)
Help!
Have not seen such an issue so far... I'm with Studio Driver 537.70 ~ Render time turns a bit longer with 4.22 but not significant.
Below preview is witg Ground Fog Off and On...
thanks for the answer crosswind!:) I will try putting the parameters of your second image for the fog. I don't know if it would be useful to update my graphics card drivers.
No problem ~ Just update your driver with Studio version if the fog's parameters don't help...
