Does anyone make male swimtrunks with mesh lining?
nomad-ads_8ecd56922e
I remember wearing swimtrunks with a fine mesh lining when I was a boy. The trunks are the sort that are like loose boxer-shorts on the outside, but have a more underwear-like inner section sewn in, meant to let the water out more quicky but keep the family-jewels from chafing against the outer part and keep them out of sight of the leg openings.
From a quick bit of searching, it doesn't look like there's anything like that for Daz, but I didn't really do a comprahensive search.
Post edited by nomad-ads_8ecd56922e on
Having two layers of polygons like that so close together, could likely lead to pokethrough or dforce explosions, hence why you can't find it in a 3D model. And there is only a few specific scenarios where that second interior brief layer would actually be seen,
I guess you could add a geometry shell to a pair of shorts, position it inside the mesh and apply an appropriate opacity image.
Well, I think I recall seeing other garments with an inner part and an outter part, such as a short skirt with integrated undies/bottom, for Daz, so apparently it IS possible. In any event, I was picturing fairly loose-fit boxers-ish sort of outer with some gap between the integrated inner-part that behaves llke tighty-whities. Basically sorta-tight undies integrated into loose boxers.
