Face Transfer 2
rbtwhiz
Basic Overview
Face Transfer 2 (sku::92487)...
- ... utilizes a newer version of a 3rd party library (itSeez3D)
- ... performs better image projection than the previous version
- ... produces higher resolution textures than the previous version
- ... is Genesis 9 centric
- ... does not add or improve support for prior generation figures
- ... does not improve the image projection quality on prior generation figures
- ... does not increase the texture resolution on prior generation figures
- ... for Windows 64-bit
- ... Genesis 9 is the preferred figure if the plugin is present/enabled (when Figure: Base: is "Auto")
- ... Genesis 8 is the preferred figure if the plugin is not present/enabled (when Figure: Base: is "Auto")
- ... for macOS 64-bit (macOS Ventura 13.2 or newer)
- ... is compatible with Apple silicon (e.g., M1, M2, M3) via Rosetta 2
- ... only supports Genesis 9, so the plugin must be present and enabled
- ... extends the Face Transfer pane from the previous version (sku::63529)
- ... if the previous version is not present/enabled, it does not matter if this plugin is - the previous version provides 'core' functionality
- ... will use the selected figure if it is a supported figure on the platform
- ... will watermark previews of projected images unless registered
- ... will remove the watermark during the trial for the first 3 saves
- ... the previous version and this version have separate 3 save trials - the previous one for Genesis 8/8.1, this one for Genesis 9
- ... will not watermark previews or saves if registered
Trials/Registration Breakdown
Breakdown of the expected behavior as it pertains to trials/registration (when Figure: Base: is "Auto") and the Generate button is clicked:
- If Face Transfer (1) is not registered...
- If Face Transfer 2 is not registered...
- If no figure is selected...
- If Face Transfer 2 trial saves remain...
- Load clothed Genesis 9
- Watermarked preview
- Save enabled
- If no Face Transfer 2 trial saves remain...
- Windows
- If no Face Transfer (1) trial saves remain...
- If Face Transfer (1) trial saves remain...
- Load clothed Genesis 8
- macOS
- Save disabled
- Windows
- If a Genesis 9 figure is selected...
- Modify selected Genesis 9
- Save enabled
- Save disabled
- If a Genesis 8(.1) figure is selected...
- If Face Transfer (1) trial saves remain... (Windows only)
- Modify selected Genesis 8(.1)
- Save enabled
- Windows
- macOS
- Save disabled
- Windows
- If Face Transfer 2 is registered...
- No watermark
- Save enabled
- No watermark
- Save enabled
- Save enabled
- Windows
- macOS
- Save disabled
- Windows
- If Face Transfer (1) is registered... (Windows only)
- Save enabled
- No watermark
- Save enabled
- Save enabled
- Save disabled
- No watermark
- Save enabled
- No watermark
- Save enabled
- No watermark
- Save enabled
- No watermark
- Save enabled
Support Assets
The Genesis 9 Starter Essentials product has been updated (2023-12-15) to include files used by Face Transfer 2 while performing certain tasks. Not installing the update will result in warning messages that indicate a referenced file cannot be found.
Post edited by rbtwhiz on
This discussion has been closed.
