NEED HELP WITH DIM
JohnDelaquioxJohnDelaquiox Posts: 1,195
If someone could please help me. I'm trying to get back into DAZ. I just purchased a new 4T SSD for my content. I Changed The Install DIrectory on DIM but it does not install to where I have selected. I don't know where it was installed. Could someone please help?
  • crosswindcrosswind Posts: 7,890
    You just go to DIM - Installed tab, select the product you've installed, right mouse button menu - Show Installed Files... You'll find where the files locate.
  • Unfortunately it does not provide to drive letter or root folder
    623 x 1033 - 173K
  • DartanbeckDartanbeck Posts: 21,715
    edited December 2023
    Here you go, buddy! Just made this for you. Hope it helps!
    Post edited by Dartanbeck on
    The library folder is on the top of this page -
    If the product was successfully installed, the files on this page would be hyperlinks in blue... If you happened to delete / move the library or product folders / file or sth.  these files would turn black...
    Pls dbl-check the installation path and try to re-install...
    1151 x 954 - 190K
  • Moved to Technical Help as it is not a Daz Studio application question.
    It might help to post a screen shot of your installation tab in Advanced settings.
  • JohnDelaquioxJohnDelaquiox Posts: 1,195
    Thank you all!
    Post edited by JohnDelaquiox on
