Viewport Animation Only Freezing(everything buy Iray)
edited December 2023 in Daz Studio Discussion
Hi All,
Im wondering if anyone has any insight into an issue ive been facing where if i try to play back any "animation" even in a blank scene the animation locks ups up. This happens for every viewport mode except Iray. Ive scoured the forums and tried everything ive found. Including reformatting my C drive. However, even with daz studio being the ONLY software installed with resh everything problem persists.
Interestingly enough some of my old scenes work flawlessly untill i delete any item in the scene related to a daz figure( genisis through G9). Changing props, poses, materials doesnt affect those working scenes.
In "broken"/new scenes I can play most animations back in near real time if im set to iray. If gone through all the draw settings one by one and the interface preview settings nothing helps this issue. Reformatted several times and tried bothe the nvidia most recent drivers for both studio and game ready.
I cant begin to understand this issue as it happened suddenly with no changes to my system, and Iray works flawlessly and if i use the "Step: Next frame"  I can scrub through even dense scenes with 10 plus characters and environment in texture shaded mode with minimal lag. but as soon as i hit the play buttong even on a blank scene it takes up to 15 seconds to move 1 frame.
Current build:
RTX 4090
32 GB ram
windows 10
ryzen 7600X
Post edited by XaxchKuget_70c49963d4 on
  • Does it help if you waggle your mouse around? There is a known issue with playback in the current General Reelase, fixed in the current Public Build.
    This is in aniMate, right?
    Go into the timeline and play it through with it set to "Play All Frames" (Hamburger menu on right side of timeline, toward the top of the list of options)
    After that, it'll play though fine for you.
    This hasn't started happening to me until 4.22
    Ooh well look at that. Thats an interesting bug. ya wiigglong the mouse in the anime 2 tab works.
    The "play all frames" didnt work to playback smoothly but setting tthe loop animation to off under the same menu did. Thanks!
