My eyeballs are acting spazzy
DDCreateDDCreate Posts: 1,404
For some reason when I try to use the Janna model I just bought today, her eyes filll in very dark and you can barely see the cornea. I tried applying other eye balls. Olympia's sorts work in that it turns the whites of the eyes from black to blue. Anyone know what might becausing this?
1600 x 1784 - 413K
  • barbultbarbult Posts: 24,884
    Maybe it is just a preview issue. Do the eyes render correctly?
  • ToborTobor Posts: 2,300
    What renderer? If it's Iray, and the eyes don't come with Iray presets, some settings for 3Delight can cause dark corneas. Try a more generic eyeball shader for Iray, or re-apply Water-Thin to both eye surface and cornea, and play around with such things as the Refraction Weight and Refraction Index. (If you use the same shader for both, you might get fireflies but these will generally render away in time. You can also try making the cornea surface Thin-Water.
    Have no ideas if you're using 3Delight.
    If it is just a preview image, there is no way to say if there is anything wrong.  Due to the various shaders used, the settings may show different things in the preview...all will be very different than the render, anyway, but what they show in the preview may be wildly different.
  • dracorndracorn Posts: 2,345
    I agree with mjc1016. The preview can be radically different from the render. I, too have experienced the strange eye darkening, but it looks good in the render. It's not just faces: I was just using Sun Hall, and its preview is very dark, but renders with proper light.
