shell not moving with body during animation
![ericross57](https://secure.gravatar.com/avatar/8ee7eecb32a19ee26e012b0020dd6bc4?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F8ee7eecb32a19ee26e012b0020dd6bc4_100.png)
Title. The geoshell will simply not move with the characters' body during the animation any advice?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/3e/9df52c4daec4e7aa7a7fda2ac5f1a7.png)
1436 x 1128 - 716K
I have seen this problem in Unity, as well.
Would like to know a solution to this issue too, if anybody knows.
I tend to avoid using geo shells as they can cause issues.
Things you can try -
If your not using head morphs - Add the helmet to the Head bone.
Do the shells have a mesh renderer or a Skinned meshrenderer? If it's a mesh renderer, then it won't animate with bodies skeleton.
If it is a skinned mesh renderer, is the skinnedmeshrenderer using the bodies skeleton for animating?
Does the suit have extra bones in it ? I've seen this cause issues before. Maybe multiple bones call hip ?
Also, when exporting, the geoshells, or anything that moves with the body, they should be "under" the figure [ie part of the figure].
You've probably exported this as a separate object to the figure.
