JavaScript seems to be disabled in your browser. You must have JavaScript enabled in your browser to utilize the functionality of this website.
We can design UI for Carrara 3D Extensions using MCSketch Tool.
Building UI for Carrara 3D Extensions
that looks pretty awesome I Samuel.
Headwax said: that looks pretty awesome I Samuel.
Headwax said:
Thank you; I wish we had more documentation for Carrara SDK.
I believe in the sdk for Carrara 7 you can find more docs. But not sure.
rk66 said: I believe in the sdk for Carrara 7 you can find more docs. But not sure.
rk66 said:
Thank you, it is good I was hoping for good detailed tutorials explaining all the functions of Carrara SDK library.
I Samuel said: rk66 said: I believe in the sdk for Carrara 7 you can find more docs. But not sure. Thank you, it is good I was hoping for good detailed tutorials explaining all the functions of Carrara SDK library.
I Samuel said:
Chap called Fenric used to be a mine of knowledge . Made plenty of pkugins. I wonder if he ever pops in
@Fenric :)
I'm sorry to bring you a little bit of sad news. The docs (Overview.pdf and CookBook.pdf) in both SDKs are exactly the same.
I Samuel said: Headwax said: that looks pretty awesome I Samuel. Thank you; I wish we had more documentation for Carrara SDK.
I too wish we had a better, more complete, documentation. However there are code snippets in the include files that will show you how to use it.
Another way to access the SDK is by using the SDK Reference. But you'll have build it yourself (see my post in the Developer forum).
Tip: Download all the sourcecode from the developers that went OpenSource (e.g. Inagoni, Digital Carvers Guild, ... ) and learn from their code.
RuudL said: I Samuel said: Headwax said: that looks pretty awesome I Samuel. Thank you; I wish we had more documentation for Carrara SDK. I too wish we had a better, more complete, documentation. However there are code snippets in the include files that will show you how to use it. Another way to access the SDK is by using the SDK Reference. But you'll have build it yourself (see my post in the Developer forum). Tip: Download all the sourcecode from the developers that went OpenSource (e.g. Inagoni, Digital Carvers Guild, ... ) and learn from their code.
RuudL said:
Thank you so much!
@Fenric :)
Thank you so much!
