How to do a simple character black silhouette
I want to have genesis 8 female posed in a dance pose with no scenery or environment and props etc but I want to iray render her just as a black silhouette of herself. Is there simple way to do this pls.
  • crosswindcrosswind Posts: 8,101
    edited December 2023
    Yes ~
    First make a pitch black figure - Load a G8F Dev Load into the scene, give her a dance pose. Go to Surfaces pane and select all surfaces, set Base Color to 0,0,0,  zero Glossy Layered Weight property. Select whatever a surface, save a Shader Preset.
    Add Wearables as you wish to the figure, Surfaces pane, select all items' surfaces, load the save Shader Preset.
    Render a PNG with Scene Only, no light.
    2560 x 1400 - 233K
    2560 x 1400 - 82K
    Post edited by crosswind on
  • ToobisToobis Posts: 967
    crosswind said:
    Yes ~
    Thanks but could you tell me how to save a shader preset please.
    Toobis said:
    crosswind said:
    Yes ~
    As below SS ~
    2560 x 1400 - 418K
  • Presupposin' one is viewing the figure from the front, go to the back view and add a long distance light for that location. Then return to the front and generally speaking, it should be nice and black.
    gottit thankyou all :)
