Active pose to drag full body?
![jamesramirez6734](https://secure.gravatar.com/avatar/f860601803ee3d2b13a507aefc4f7f20?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Ff860601803ee3d2b13a507aefc4f7f20_100.png)
When using the active pose tool, it will drag either the upper or lower part of the body depending on the bone selected.
Is there any way to drag the full body, for example, if you were to grab the head and pull the character into a flying superman pose? (affecting arms, legs and body as part of the same movement)
Or is this not possible in Daz given the top and lower parts are separate?
For context I'm trying to have a figure roll forwards into a yoga pose (so there hip moves forwards), but the active pose tool doesn't move the location of the hip.
You have to Pin some joint(s) first... For instance, you just try - : Ctrl + Select both feet of the figure, press Space bar, then drag the hip or pelvis bone to a direction or drag to move freely.
