Changing how a door rotates in its frame
shg0816_13461e8196
in New Users
I bought a bunker style door, which includes the door frame, from CG Trader. I have the door imported into DAZ Studio; however, the door rotates on the y-axis in the middle. I need it to rotate from the side, where the hinges are. Is there a way to do that in Daz, or do I need to make my changes in blender, then import?
You can use the Joint Editor tool to move the centre point, when you select the tool from the Tools menu with the prop selected you will see green cross hairs - those mark the centre point, and can be dragged with the tool. I would suggest using an orthogonal view (top, say) so you can clearly see how the marker is aligning.
