Rez compilation error, resource.r not found.
Have you tried compiling swap plugin? It compiles fine but just at the post build step; I am seeing following error:
resource.r not found from Rez.
Any suggestions?
  • RuudLRuudL Posts: 208
    edited December 2023
    You'll have to create the resource.r file yourself, if it is not already there. Insert a #include for every .r file in the folder.
    In this case: #include "Swap.r"
    This is the standard approach of the Carrara SDK on Windows. The resource.r name is hard coded in the <SDK Root>\Build\BuildDTA.bat
    Post edited by RuudL on
    Thank you, this really worked for me!
  • It is interesting that I found this issue as I have not seen this before. I was planning to create a Carrara SDK development video for creating a clean template using the "Flat" primitive as an example. I deleted all the files which I felt were not relevant. Many thanks to @RuudL.
    My pleasure.
