Script to go right to parameter
I want to create a script that selects a specified parameter in the parameters tab.  For example I run my script and it navigates to path "Actor/Head/Ears/Fantasy SciFi/" and highlights "Ears Elf".  Can this even be done?  Or at the very least a script that fills in the filter field so that it'll show my parameter.
I've tried this:
var item = Scene.findNodeByLabel( "Genesis 8 Female" );
var param = item.findPropertyByLabel( "Ears ELf" );
if ( param ) {
param.setValue( 1 );
But Param comes up nil.
Any help wpuld be apreciated.
  • algovincianalgovincian Posts: 2,622
    I've tried this:
    if ( param ) {
    It's been a while since I've done any DS scripting, but I believe findPropertyByLabel is case sensitive. I suspect the "L" may be the issue.
    HTH.
    - Greg
  • Thanks algovincian.  Turns out "Ears Elf" isn't a property, it's a modifier, so it can't be searched the same way as a property.  I ended up using the following.
    var par = Scene.getPrimarySelection();var obj = par.getObject();var mod = obj.findModifier("PHMEarsElf");    mod.getValueChannel().setValue( 1 );
    It still doesn't navigate to and visually highlight my parameter but I guess that's a pipe dream.  I've since abandoned that idea for a new approach.
