Diffeomorphic - Problems with favorites (custom morphs)
![corycubbage](https://secure.gravatar.com/avatar/7498f20c9470708312b2b69184ad7973?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F7498f20c9470708312b2b69184ad7973_100.png)
Hello!
I'm using Blender 4.0.2, Daz 4.22 and Diffeo 1.7.3.1938.
When I export a G8F character from DAZ without favorites and use easy import into blender, everything works as expected. The clothes follow the character and I can create a rig without a problem. When I attempt to load a G8F following the same process with favorited expressions in daz, I'm running into problems (the clothes do not follow the character properly). The favorited morphs are importing correctly on the face (they are expressions and work as expected), but I must be missing a step because I can't seem to get this to work correctly. I have all of the default Gen8 import options selected (including transfer to clothes). I have tried using just the "Daz Favorites" Easy import option as well as saving out those favorites as a json file and then using the "Use Favorites Morphs" option in the importer as well.
Running blender from the command line, there are no import errors for the character. The first error appears when trying to create the rig, but clearly, the problem already exists since I can't move a bone and have the clothes follow after the custom import.
Help!
Is it possible that the clothes rig and the G8 rig are not being merged during this import process?
In easy import there's presets for the various genesis figures, including G8, please use the G8 preset for G8 figures. Then use "daz favorites", and eventually "baked correctives" if you want the exact jcms for a custom figure. Add "merge geografts" if you use geografts. Other than that it should work, if not you can open a issue at bitbucked with exact steps for Thomas to look at.
https://bitbucket.org/Diffeomorphic/import_daz/wiki/Import/Easy Import DAZ
