rotating propellers
calaopiecalaopie Posts: 215
edited November 2015 in New Users
I downloaded the plane of tf3dm. The aircraft is in the obj format and works correctly. The aircraft folder is a file with textures representing the rotating propeller. I tried to replace normal static texture propellers on these rotating but does not look it correctly.
Anyone know how to replace this file?  Here it is probably something similar http://www.daz3d.com/blue-sky-biplane
800 x 600 - 501K
436 x 380 - 75K
Post edited by calaopie on
  • Linking to something "similar" doesn't help too much.  Without knowing anything about the actual model you're trying to get working, it's hard to say what might need to be done.  Can you provide a link to the specific model on tf3dm that you are using?
  • prixatprixat Posts: 1,590
    Hi Calaopie
    The prop is modelled so you have to make it transparent to hide it.
    Then replace each prop with a disc, I used a very flat cylinder primitive.
    The supplied texture can then be applied to those discs.
    On the attached image I made the discs slightly transparent and left the original props slightly opaque.
    800 x 400 - 360K
    Post edited by prixat on
  • calaopiecalaopie Posts: 215
    Thanks a lot, looks pretty goodyes
    640 x 480 - 366K
  • Here is a short tutorial on another method to make spinning prpellers:
    http://www.colacola.se/howto_propblur.htm
  • LinwellyLinwelly Posts: 5,991
    You could try as well to use motion blurr, but that requires the propellers of your prop to have a rotating morph
  • Roman_K2Roman_K2 Posts: 1,253
    edited December 2015
    Fascinating topic. I liked the tutorial page. It seems to me that in general with these situations you want more variance and and a bit more contrast, noise or jitter while keeping the circle of the prop tip wispy, like cirrus cloud. It's not just a question of darkening the circle or lightening it or increasing the contrast... it's usually a mix of a lot of stuff. Also it's a sunny day, judging by the clouds so a bit more light on the nose of the plane. See herc2.jpg attached.
    Related: the Toon Plane in the DAZ store has a bit more of a complex shape standing in for the propeller... but I looked at the .OBJ file using Hexagon and there is a propeller embedded in the circular shape, which doesn't turn - or at least it didn't turn for me. What's up with that I wonder.
    In this outtake of the Toon Plane my dog is flying around the apartment complex on a cloudy day, and I handled it by keeping the circle pretty much transparent, but with opaque gray on the left side and transparent blue (added contrast) on the right.
    640 x 480 - 163K
    1011 x 593 - 187K
    Post edited by Roman_K2 on
  • AJ2112AJ2112 Posts: 1,416
    Tried this method, didn't work for me.  Certainly hope I can figure it out though.
