Recalibrate Transfer Tool?
![texbeet](https://secure.gravatar.com/avatar/f566054604523f501c61d7950913efc9?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Ff566054604523f501c61d7950913efc9_100.png)
Occasionally the red-green-and-blue icon for the Transfer Tool gets ,miles away from the object I want to move around.
Is there a way of recalibrating it so my character (for instance) is in the same place as the icon?
If you mean the gizmo far away from the character...in most cases that results from the translate values on Hip node of your character, pls take a look a it.
Like the example as attached screenshots, a simple way - you just add the axis value from Hip node to the Root Node, then zero the values on Hip node.... then gizmo will be back to root node while keeping figure's positon with no change.
In general, never add values to X / Z Translate on Hip node.
