when the geometry editor wont selects only pieces-is there a trick to selecting the whole object in
when the geometry editor wont selects only pieces-is there a trick to selecting the whole object in order to delete it?
thanks
  • crosswindcrosswind Posts: 7,828
    If you mean select and delete the whole geometry of the object... right mouse button click in Viewport - Geometry Selection - Select All... then Delete Selected Polygons
  • VicSVicS Posts: 1,273
    There is a table set with chairs, I want to move the chair by itself but all chairs and tables move at the same time so I was trying to isolate one of the chairs by deleting it then with a duplicate set deleting everything aside from the one chair I wanr to move
  • lilweeplilweep Posts: 2,549
    marquee select mode while in wireframe drawstyle is also a good way to select part of object, since it will select everything within the box/shape you draw.
    also 'select connected' option etc.
  • SofaCitizenSofaCitizen Posts: 1,950
    For something like that it should be pretty simple. With the geometry editor select part of the object you want to delete, right click, Geometry Selection -> Select Connected. If the chair is a bit more complicated (e.g. separate seat) you may have to do that a few times for each part.
    If it's complicated, then select everything you want in wireframe drawstyle with marquee tool, so you can select in one fell swoop/mouse movement.
    thanks for all the help
