Larger Render
Styles2304Styles2304 Posts: 0
Is there anyway to render the active viewport with 3Delight but designate a larger set of dimensions for the image? I suppose what I'm actually asking is if there is a way to increase the resolution of the rendering?
  • SimonJMSimonJM Posts: 5,993
    Yes, I believe you need to select the option to render to a new window for the dimensions you specify to 'take'. Press Ctrl-Chift-R to get up options.
  • Styles2304Styles2304 Posts: 0
    ok . . . I wasn't understanding the process. I'm with it now though. Thanks.
  • JaderailJaderail Posts: 0
    You can also Render to File in the size you pick. FYI.
    Indeed you can!
    Character Render
    Thanks again.
