V4/M4 morphs.
starboard
I have had some good results shaping a custom face in Carrara using the M4 morphs on an M4 figure. However, when I try to customize a V4 face the morph options are very limited. I bought the V4 Morphs and they seem to be mounted correctly..But there are not nearly so many morphs as there are for the M4. For example there are no morphs for moving the eyes apart or sizing the eyes or shaping them in different ways. I tried loading the M4 morphs into the V4 figure but that does not seem to work.
Are there more v4 morphs that can be obtained ? Can the M4 morphs be used in the V4 ?
Thanks, for your time and thoughts,
Starboardtack
I have been able to inject the the M4 morphs..and they appear in the parameter list in V4..However the sliders when operated do not make any changes that I can see in the V4 model. Still trying...
Starboardtack
Finally figured it out. The morphs come in two levels.. Morph + and Moph ++ Although I had bought the additinal morphs they had not loaded...After loading them manually..Most of them are working.
