Trouble Merging Geografts
![celticsamurai](https://delorean.daz3d.com/forums/uploads/userpics/940/nPQ4M1S2GF3GQ.jpg)
Whenever I attempt to merge two geografts (that need one another to be complete), the geometry looks completely distorted in that area. Is there something I'm doing wrong?
Easy import should merge geografts correctly if the option is used. To merge by hand a hierarchy of geografts in parent child relation, you can try to select all of them, then the figure last, then merge. If this doesn't work you can merge by parent child couples following the hierarchy. If this doesn't work either then there's probably a bug, if so you can file a bug report, please specify your setup and exact steps to reproduce the issue.
Be sure to update to the latest development version since there's many bug fixes, especially for blender 4.
https://bitbucket.org/Diffeomorphic/import_daz/wiki/Home
