Help me find the right Neck Morph (SOLVED)
HylasHylas Posts: 5,070
edited January 2024 in The Commons
Which slider lets me widen the lower neck (A) without changing the upper neck (B)? (Genesis 8)
I have about a hundred morph packs, but the moment I need a specific one... indecision
646 x 803 - 51K
Post edited by Hylas on
  • JasmineSkunkJasmineSkunk Posts: 1,906
    edited January 2024
    If you only have the standard morph pack, you may not have a morph for this, but...
    I have two possible solutions
    1. Rarestone's face morph set for G8 female that has extra neck morphs here: https://www.daz3d.com/rarestone-s-face-morphs-collection-for-genesis-8-female
    And G8 Male here: https://www.daz3d.com/rarestone-s-face-morphs-collection-for-genesis-8-male
    2. But you may have some success by unhiding the scale options in your parameter tab. Then you can adjust the scale as needed on independent xyz axis
    Go to the Parameter tab and look for the little 3 lines and arrow in the upper left corner of the tab and select unhide. This will allow you to see the xyz scale sliders when you select indidual parts of the figure in the scene tab. Image attached shows where to find it. Hope this helps!
    1726 x 871 - 80K
    Post edited by JasmineSkunk on
  • HylasHylas Posts: 5,070
    I have Rarestones morph pack, how's the slider called? Maybe I'm blind but I can't find it...
    edited January 2024
    Hi I just checked and while there are extra neck morphs none to do as you want..
    However... the other option works fine. I have included a better image to follow.
    1. Select 3 line square in upper corner of Parameter tab and choose "Show hidden properties"
    2. Then select the neck joint on your figure in the Scene tab
    3. Then you can use the xyz scale sliders  (which will now be visible in the Parameter tab) to size the body part.
    I hope this works for you! smiley
    1920 x 1080 - 360K
    I see now I selected the oposite neck bone... but you can select the one that you want. It should work for you! smiley
    That did the trick, plus I learned something new. Thank you!
    Glad I could help! smiley
