Randomizing a shader
How do you make each rail tie look different?  If I copy the tie over a length of tracks, they are all the same.  Is there a way to have an infinite variation of grain angles and shades and other variables?
  • FifthElementFifthElement Posts: 569
    edited December 2015
    Post edited by FifthElement on
    Does it really matter?
    Are you rendering that large or so close that the ties will be more than just brown streaks?
    And if it is that close, you won't have more than a couple in 'focus' that it would really be very noticeable that they are 'clones'.
    One method that I can think of would be to use more than one tie.   Let's say 3 of them will be close enough to notice, make each of them different and then copy the "set" instead of a single tie.
  • TimBoTimBo Posts: 151
    I am playing around and trying to make a rocket sled.  So yes while sitting there waiting for the engines to start you will see a repeated pattern for the entire length of the tracks.  I am using a preset wood pattern for now.  In reality I assume they use concrete ties but that is boring.
    Yeah,,,in that case you would need some more than 3 or 4 different ones.
    One of the ways to do that in most shading languages is to introduce noise into the shader...it's been way too long since I've done anything in Carrara to remember how to do that.  But in Blender I would mix in some noise to vary the wood a bit.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,570
    You can try a global shader with noise in multiply operator with your colour or what ever channel you use to drive the variation, so long as the camera moves and the objects remain static it should work.
    It may need to be fractal noise, forgotten, rendering a long ani so cannot check.
    been a while since I tried it as I mostly use Octane but I varied leaves on trees that way.
  • PhilWPhilW Posts: 5,148
    Definitely take a look at the Sparrowhawke plugin linked above, it is intended for exactly this kind of situation to give variety to duplicates. I did a demo/tutorial for it here:
    https://www.youtube.com/watch?v=ryh6bU8vC4Y
    After watching the demo I was impressed.  I will enjoy having this plugin around.  It is exactly what I need for what I am working on.  Thanks.
  • cdordonicdordoni Posts: 583
    It looks like Replica can do randomized shading also:
    http://www.inagoni.com/e107_plugins/content/content.php?content.5
