SOLVED - Updating Geometry Questions
Hi! :) So, I have been trying to teach myself some stuff and have been practicing by converting clothing to G9, but I've run into a weird problem I don't understand. Most often, I am able to make adjustments to a mesh in Daz Studio, then export it and then "update geometry" to make the item of clothing fit better. But something weird is going on with the Cinderella Ballgown for G2 corsette. Even if I load it in and immediately export it out without making ANY adjustments at all, it will say "imported geometry does not match the geometry it is importing". I checked with some other geometries and am not havig this problem. Only with this corsette. Anyone know what might be going on and how to fix it? Thanks in advance!
It will often be if it isn't in base resolution, or there might be another object parented to it, so you have exported both.
THAT was it!
base resolution! THANK YOU!!! I was losing my mind. LOL
